- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi, yes I have done both types of recover. I have to further test this, but so far someone in my office offered this method of cleaning/purging the file and no errors have come back (fingers crossed)...
"Open dwg file > do DXFOUT command > save as 2007dxf version > open the dxf file> do AUDIT and PURGE > resave back as dwg file > Done!
Sometime the number of XREF files and how it's xref in can slow down your files too. I would suggest running the DXF steps (above) in all your files, even the xref dwgs (if the file is greater then a few mb, it usually calls for a dxfout file clean up) and then check if all your XREF files can be xrefed in as overlay vs. attachments (for example, if the baseplan (walls and hatches) that we talked about is xref as an attachment into 5 drawings, CAD will circular reference when it's going back and forth to relink the same dwgs 5 times. and that can def. slow down production and saving time) Hope this helps."
