en respuesta a: ian.mag
I just read this in another thread, so I stand corrected. Thank you for pointing me to clarifying overlay vs attachment a little more...
"Overlaid xrefs
An overlaid xref does not load or bring with it any nested xrefs. For example, if you xref "A" into your parent drawing, which contains a nested xref, drawing "B", only drawing "A" will be referenced in. Drawing "B" will not be loaded into the parent drawing because it is a nested xref.
Attached xrefs
Attached xrefs, when referenced into a drawing, will include nested xrefs, which means if drawing "A" is referenced into your drawing and it has nested xrefs "B" and "C" in it, drawings "B" and "C" will be attached to the parent drawing along with drawing "A."
