301 Vistas, 4 Respuestas
Printing directly without publishing
I wanted to know how we can print a large number of DWG/DXF files directly to printer without publishing it to PDF. I am able to send a drawing file straight to printer but unable to send more then one file straight to printer without publishing it to PDF. Any form of help will be highly appreciated.
j.palmeL29YX
en respuesta a: Anonymous
Do you know the SheetSetManager?
Or you can use a scipt file.
cadder
Jürgen Palme
ian.mag
Hey,
As pointed in the above comment by @j.palmeL29YX , sheet set manager is a powerful tool that enables you to manage your sheets. You can get started here
maratovich
No problems.
Use this:
https://youtu.be/rK9WLeJHA1M
Print from model or layouts.
You can select many files at once or specify a folder with files.
You can choose any printer.
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
pkolarik
Why not just simply Publish your dwg files direct to the printer? (use the built-in Publish command, but skip the pdf step)
