jayhar
en respuesta a: Alfred.NESWADBA
Hi @Alfred.NESWADBA
1. All Mtext are justify Top right, so i can easy select grip and move to Vertical Xline.
2. Leader can also easy select grip and move to Vertical Xline.
3. But Rotate Dimension cannot stretch to Vertical Xline using grip (Rotate Dimension is Text Override using space bar gap)
watch this video & dwg is attached
Mtext, Leader & Dimension are move to Vertical Xline for drawing in good order.
if you did not understand watch this video also
Jayhar.M.J
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
