03-04-2019
09:38 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-04-2019
09:38 PM
>> I actually saved it in several different versions of DXF...all the way down to 07.
First please save in current DXF-format (DXF 2018), everything older than that could result in missing or incorrect items for those which can't be converted to an older object type.
Also please make sure you have plain AutoCAD and your dwg-file does not contain proxies. Saving proxies or objects from vertical applications also might have issues when saving to DXF.
>> The drawings are 3D, so maybe the file needs to
>> be flat 2D before I export it?
Then you don't have the same content any more.
Maybe important to help: which reason do you have to save the file to DXF, what should happen then with the data?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
