441 Vistas, 3 Respuestas
commands working not properly
Dear technical team,
                         while we are using this autocad version 2016 ,we are facing lot of difficulties with commands.Commands not working properly,Some of keyboard options,commands  are not working and not visible particularly in auto cad.please provide a solution for this problem.we have 2016 version in one machine only.In that only we are facing these difficulties.previous selection of objects before commands is also not working.
S.Faris
en respuesta a: Anonymous
Or Type PICKFIRST(enter) provide value 1
We are just users like you, not technical team :cara_con_una_leve_sonrisa:
SALMANUL FARIS
alex101000
All updates and hotfix installed ?
Try reset default settings.
What is the value of the PICKFIRST variable?
jayhar
Hi @Anonymous
<<<<<.Commands not working properly,Some of keyboard options,commands are not working and not visible particularly in auto cad>>>>>>
1. Reset the CUIx in AutoCAD click here
2. Shortcut keys not working properly in AutoCAD
3. The Select and Previous Commands in AutoCAD
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | AutoCAD randomly crashes or freezes
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
