03-03-2019
10:22 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-03-2019
10:22 AM
Error :
Command: EXT
EXTRUDE
Current wire frame density: ISOLINES=4, Closed profiles creation mode = Solid
Select objects to extrude or [MOde]: 1 found
Cannot sweep or extrude a self-intersecting curve.
1 object removed from selection set.
Select objects to extrude or [MOde]: *Cancel*
Solution :
Do a Boundary inside the wall and create another polyline which will help to remove Self Intersection error.
SALMANUL FARIS![]()
