2000 Vistas, 9 Respuestas
03-01-2019
10:36 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-01-2019
10:36 AM
Export PDF to the same folder as the DWG
I'm using LT 2019 and required to use Export PDF to output the finished documents.
At the moment, when I Export to PDF, Autocad tries to save the PDF in the folder for previously opened drawings and I have to manually locate the folder with the current drawing. Is there a setting to automatically export the PDF to the same folder as the drawing itself?
Using Publish (or similar methods) is not an option.
