674 Vistas, 4 Respuestas
AutoCAD 2019 DXF Export Won't Reload and Corrupted
I am trying to export DWG files to DXF for use in a third party application, but every DXF I export does not load into the third party application (says the files are corrupted and to check if they load in AutoCAD).  When I try to load them in AutoCAD (within 1 minute of exporting successfully), the DXF file will not load.  I just get a black screen and a message that says, "press enter to proceed."  When I press enter, it loads nothing and returns to the home screen.  I am not sure what I am doing wrong.  I tried different versions of DXF files, tried ASCII and Binary, and tried to remove the linetype dependency:
https://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/195...
Any recommendations or advice.  I am amazed I cannot load them back into AutoCAD after they appear to have been successfully exported (or saved as dxf).
