Alfred.NESWADBA
en respuesta a: abhima_av
>> but it cant working
Sorry to hear that.
Looking to your drawing:
  • Your pagesetup (for Layout 1) shows "ISO A3 (420 x 297mm)"
  • Your block-size is 408 x 290
So I suggest you need to edit your block to fit to 420 x 297.
But again, I'm not sure which units you want to work as the file units are Inch, the layout-plot units are set to Inch, your paperformat is set to metric Millimeter. Anyway, also paper-format 17" x 11" does not match the format of your title-/border-block
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
