en respuesta a: ChicagoLooper
Thankyou ChicagoLooper,
The DWGUNITS are set to 3 (millimetres).
However I did as you suggested ("On cmd line, type DWGUNITS and proceed through all options, carefully reading and selecting each one according to your needs.") and carefully went through the options.
At the end of the routine I came across this:
Scale objects from other drawings upon insert? [Yes/No] :
I changed it to which seems to have fixed it.
AutoCAD must default older files to "inches" even though the units are set to "millimetres", which is odd to me.
