OliverE
en respuesta a: Kent1Cooper
Ok so the -DIMSTYLE APPLY is only applied to dimensions that are a part of a selection, not every dimension in the drawing that is using the particular current style?
I've kind of strayed from what I was initially trying to accomplish here but your response has been helpful for many other uses. Originally I just wanted to edit the Baseline Spacing in the Style Editor for a dimension style and have it update the spacing on any Baseline Dimension in my drawing using that dimension style. However, I've come to realize this is one component of the dimension style that is not updated when you edit a dimension style. Instead I used the DIMSPACE command for each set of dimensions.
