Kent1Cooper
en respuesta a: OliverE
@OliverE wrote:
So it seems the -DIMSTYLE command applies to all dimension styles, even ones that have overrides?
When you edit a dimension style should it not update all the dimensions using that style except the ones with overrides? That's what I'm trying to do.
The -DIMSTYLE APPLY approach imposes the current Dimension Style, and  any current System Variable settings that may differ from those in that Style's definition, on all selected Dimensions, of whatever their current Style or overrides.  So if you want to use it to "fix" Dimensions, it's necessary to set the desired Style current and clear any overrides [as suggested by others earlier] first.
For me, editing a Style definition does  update the not-overridden properties of Dimensions using that Style.  I wonder what you may be doing differently than I am, if it's not working that way for you....
Kent Cooper, AIA
