- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
First off, I really appreciate you putting in the effort to help me on this.
So the columns were made by creating a closed polyline and using the presspull command so that they snapped to the intersecting 3d object, or halfway through it. I never scaled anything in this drawing.
A few things to note:
1. this model exported perfectly fine the way it sat when the USC was rotated. Im not sure if that has anything to do with the problem however, just pointing out I got this model it export perfectly at one point in time.
2. I just created a box, then another box, intersected them, unioned them, and exported an stl. Literally nothing else. Same issue, wonky geometry. This confirms my belief, it is not an issue with this particular model, as I cannot even get a box to export properly. It must be an issue with my settings or workflow.
3. I opened a new drawing, tried #2 again and it worked fine, two boxes unioned perfectly, copied my model and pasted it into the new drawing and wonky geometry again.
