02-19-2019
01:06 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-19-2019
01:06 PM
I created an stl file in AutoCAD of just one of the solid objects and then imported that solid into 3ds Max. Here are the results. Not good! The columns are much different. The black areas are where the surface normals are reversed. Unifying the surface normals did not help (top image is AutoCAD bottom is 3ds Max).
Importing the dwg file of the one object into 3ds Max yields the following.
Again, not good. The columns are not square.
What was your workflow to create the columns in AutoCAD? Did you scale any of the geometry?
lee.minardi
