02-19-2019
11:46 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-19-2019
11:46 AM
There are many non-solid objects in the file. Do not use a select window for exporting. Instead, open the properties dialog box and select one object at a time and the properties dialog box should reflect that you only have solid objects selected. Move these objects to a frozen layer and see what is left behind. Give your stl export command when only the solid layer is thawed so you can be sure you do not have non-solids selected. I was able to create an stl file with just solids selected.
lee.minardi
