02-19-2019
05:41 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-19-2019
05:41 AM
AutoCAD requires the geometry be a solid object for exporting as an stl file. Are you sure that you have a solid model? WHat does it say in the properties dialog box for the geometry? There should be no need to use surfsculpt if the model is already a solid. It looks like you have a surface, not a solid, for the wall in the area I circled below. Create a copy of your model with only solid objects and then try creating the stl file. I doubt that facetres is the issue as all the surfaces appear to be flat. More likely, you are not working with solid objects. Post the file here and I am sure the forum community will examine it for you.
lee.minardi
