02-19-2019
01:58 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-19-2019
01:58 AM
Hey,
To add on what has been said in the above comments, i would suggest you "Open the External References Pallete" while opening the drawing. In the XREF pallete you shall see all the drawing attached to the dwg file. You can then locate the file path for the XREFS attached in the drawing under the "Details>Found at/Saved path".
You may alternatively "ignore the unresolved reference files", to open you drawing but that would mean that the drawing cant really located the path for the xrefs in your computer.
