257 Vistas, 1 Respuesta
managing units in autocad file to export to other software .
I am using Autocad 2017 Student version. How to manage units in Autocad templates and files. How should be the units to export to staad.pro select/connect edition, 3ds max and revit.
S.Faris
en respuesta a: Anonymous
This Forum is related to topics related to Dynamic Blocks
The Actual forum where you should have posted this is Autocad Forum<CLICK HERE>
Since you've already posted the query, Check the below.
Check This links to know how it can be done
How to convert a drawing from inches to decimal feet in AutoCAD
MEASUREINIT (System Variable) Controls whether a drawing you start from scratch uses imperial or met...
SALMANUL FARIS
