natasha.l
en respuesta a: PremTM
Hello @PremTM,
Welcome.
1)When changing dynamic constraints to annotational it takes on the appearance of the current dimension style. If you change the dimension style in the Properties palette, the annotational constraint updates to the new dimension style format. I would check the assigned layer to your dimensions in the Dimension Style Manager & the "Set Current" to the Dimensions Style you choose.
2) Make sure the Set Dimension Style is "Centered"  >Text Tab (Dimension Style Manager)<
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
