3892 Vistas, 22 Respuestas
Set dimension arrowhead size in dimension style manager.
No matter what size I set it at, the arrowhead is microscopic. I have changed the overall dimension to 48.000, or to 1, it is the same size. I didn't have this problem in AutoCAD 2013.
Patchy
en respuesta a: Anonymous
Check this:
en respuesta a: Patchy
It is checked already.
Patchy
Attach your drawing and see.
Patchy
Check the setting, Unchecked ☺
Exactly the same when unchecked
beyoungjr
How many dimstyles do you have and are you sure you are changing the one that is used for your target items?
Blaine Young
Senior Engineering Technician, US Army
beyoungjr
Also, any text style bugs?
Blaine Young
en respuesta a: beyoungjr
I only have one dimstyle, standard. And yes, the text is wrong, too. It is supposed to be Romans, 9" tall. it is also microscopic, and not Romans.
Patchy
Maybe you're using inch & feet dimstyle in the metric based drawing.
No, inch and feet drawing.
Patchy
Let's see this drawing.
This is one of my dwt's. I just got upgraded from 2013 to 2019. I imported all of my settings.
Patchy
It is not too small, it's too BIG
Well, here, it is microscopic. I have to zoom in real tight on the end of the line to see it. I have done a zoom all numerous times. Never saw that.
Patchy
Zoom out , really far away and use command Leader and see.
Well, it looks like I went from one problem to another. Until this time, it was always so teeny tiny, it just looked like a line. the text was so teeny tiny too. Ok, how do I fix this then?
Patchy
Model space is too big
Draw it 1:1
If I use MLD mleader, the arrow seems to be good. Why would there be such disparity between the two commands? (I just want the arrow and line, don't do a lot of dimensioning, thankfully)I guess I need to go back and change all my settings in dimension style setup. I will just copy what I had in 13 again, but that wasn't working right, before. (It did work in 13, just not in 19.)
beyoungjr
Multileaders have their own style manager.  The adjustments in Multileader styles should not end up fixing a problem in Dim Styles.
Blaine Young
