794 Vistas, 12 Respuestas
Why OVERKILL does not work on Ellipses?
Alfred.NESWADBA
en respuesta a: Anonymous
As long as your ellipses are not converted to polylines it's as designed!
From the help >>>here<<<:
Removes duplicate or overlapping lines, arcs, and polylines.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
rkmcswain
It does work on Ellipse objects.
Etiquetas (3)
Alfred.NESWADBA
en respuesta a: rkmcswain
try the attached dwg-file ...
- alfred -
Alfred NESWADBA
s.borello
en respuesta a: Alfred.NESWADBA
Definitely didn't work.
s.borello
Why does it work in one of my local files?  If you have time can you please do a test on this file? I was able to overkill my ellipse.
Alfred.NESWADBA
en respuesta a: s.borello
Rotate or mirror your second ellipse ... then try _OVERKILL again.
- alfred -
Alfred NESWADBA
s.borello
Interesting… thanks Alfred!
jayhar
OVERKILL are working on Ellipses https://autode.sk/2GEAMEs
1. Check center Z value is "0"
2. Enter new value for PEDITACCEPT <0>
Jayhar.M.J
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Alfred.NESWADBA
en respuesta a: jayhar
@jayhar
Please try the same with my file ...
(again attached in 2013 format)
- alfred -
Alfred NESWADBA
jayhar
Hi @Alfred.NESWADBA
These two ellipses are different axis, so how command work ???
Overkill not working in this file.
https://autode.sk/2GFTcEW
Jayhar.M.J
Alfred.NESWADBA
Overkill should find overlapping geometry, independent of a line that goes from right to left or left to right ... and so an axis of an ellipse going from right to left or left to right.
And I guess that's why Autodesk did not mention the ellipse object in the help of command _OVERKILL.
- alfred -
Alfred NESWADBA
rkmcswain
What does PEDITACCEPT have to do with it? That just controls whether or not you get an extra prompt during the PEDIT command if you choose an entity that is not a polyline.
