Kent1Cooper
en respuesta a: Alfred.NESWADBA
@Alfred.NESWADBA wrote:
....You can use command
-INSERT
(the dash means .. no file dialog, so ready to type in the filename in the command line)
Be aware that if you want to just type the file name in that scenario, the drawing needs to be in a folder location that is in your Support File Search Path list  [OPTIONS command, Files tab].  If not, you'll need to type it in with the file path included.
Kent Cooper, AIA
