en respuesta a: Anonymous
I just started using Autocad Architecture 2019, and had my cursor/crosshairs disappear - but only in modelspace viewports.  My drawing has two viewports in paper space - the viewports were clipped (not the standard rectangle), and when I went into modelspace through the viewport, as I zoomed in with the mouse wheel, my crosshairs disappeared.  My cursor would reappear if I hovered over the ribbon, or the bottom info bar, but as soon as I went into the drawing proper, the cursor would vanish and no crosshairs would appear - interestingly if my ghost crosshairs passed over a line or object, it would light up like it normally does - which indicates it's a graphics issue.    I'm running a Dell M6700, w/ 16gb ram and a Quadro K4000 vid card (my rig is a dell laptop), so it's got plenty of horsepower - and my system is up to date.
Things I tried?  I've exited out of the program, and that seems to work OK for a bit, then randomly, the vanishing crosshairs occurs.  One thing I did try was in the Options, I turned off "demand load xrefs", since by default, it's set to 'enabled with copy' and that can slow things down noticably.  Not sure if it helped or not with my crosshair issue, but it does speed things up a hair.  What ended up working for me was re-entering paper space so my crosshairs reappeared, saving, exiting the drawing, opening up the drawing + zoom extents - I  double clicked into the offending viewport.  The crosshairs appeared.  Great.  Then, I zoomed in, and the crosshairs maintained no matter my level of zoom within the viewport.   It sure is a weird issue.
One thing you may try which also worked is clicking the 'maximize viewport' while in paperspace, it seemed much more reliable than working within the viewport the standard way.
