1253 Vistas, 5 Respuestas
Compatability wit Vectric Aspire
I am testing the trial Autocad 2019 program using a file designed in your software sent by a potential client.  I would like to use that file in my CNC router software Vectric Aspire.  The file does not seem to be compatible since it will not open in my software.  Before I purchase Autocad I would like to find a method to work around this problem. I realize this is not an Autocad issue, but do you by chance have a solution that could be attempted?  I have tried saving the file in every possible autocad extension with no success.
Thank-you
Greg
Patchy
en respuesta a: Anonymous
Did you try older format of .DXF?
en respuesta a: Patchy
I have tried every possible format in the drop down with no success.
pendean
Ask that vendor's support https://support.vectric.com/
and/or try their user support forums https://forum.vectric.com/
en respuesta a: pendean
Already tried that as well.  They recommended saving as an earlier autocad version as well.
pendean
Work with them again: send them all of your DXF files and ask them to test them for you and identify what the exact issue is... .
Remember, it is their software you want to get to work, so you and them need to find out together why your own DXF files are not working with all the versions you are creating.
