- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I'm making edits to a design that includes circles with dashed lines imported from a pdf, so each dash is an object. I'm trying to make small move/rotate adjustments to align these with the rest of the drawing. Is there a way to re-select everything I'd just selected without doing it over again, or use multiple commands while the objects are selected?
Thanks!
Justine
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Does the Previous selection option [in whatever editing command(s) you're using] do what you want?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thank you both: making a block or group would help me move the circles as a single object. And I tried out the Previous selection command and I think that would have solved my problem, too. (I ended up taking a different route that I realized would be easier than trying to figure it out at the moment
I'm still quite new to this so the more tricks I can learn, the better!
Justine
