01-25-2019
02:40 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-25-2019
02:40 AM
>> is it possible to make a type of rendering where
>> objects are well bright but not shadows?
No rendering, but you can use visual style "Realistic" (or an own defined one) for a viewport or for your modelspace.
There you can turn off shadows and you can adjust global brightness and contrast.
The quality is not the same as rendering, but it might help. (please find attached the PDF with this simple geom from a layout with multiple viewports each having different brightness assigned)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
