- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
@MrMuscl3 wrote:
.... there occurs a problem with longer text elements that contain spaces in them. These spaces are interpet to be actual line changes (pressing enter) ....
Are they really becoming hard returns? I suspect maybe it's just a matter of slight differences in overall width as applied in the Mtext version compared to as applied in the Text/Attdef version, and that it's just word-wrapping. It may be affected by the particular font, or by the particular character content. You can test it easily enough -- if you grab the Mtext width grip and drag it wider, does it "straighten out" into a single line? [It won't do that if it's really imposing Enters between lines.]
If that's the issue, try adding this to the routine, to force the Mtext version to have no limiting width, so it will never wrap to any additional line(s):
(vlax-put tobj 'InsertionPoint tins); original Text's insertion
(vlax-put tobj 'Width 0.0); prevent word wrapping
); repeat
