- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
printing without a full sized plotter
We have an older 2010 version of Autocad that works very well for our needs, but now we have a printing problem. In the past all we have needed was any printer that would take 11" x 17 " paper. However, we now need to print larger layouts, but find a full size 36" wide plotter to expensive for our operation.
I have noticed a printing option labeled "print to file" so the question I have is this. If I print a 24" x 36" layout and save it as a "print to file" can I then take that file to Staples o Office Max and have them print it with there plotter and get the 24" x 36" layout that I wanted in the first place as if we had a full sized plotter?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Yes you can but I would make that file a PDF file using something like "pdf creator".
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
"print to file" is too random and used to be the only option in the last century, but its not a wise choice this century.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I agree that PDF would be the best choice, but you don't need a printer software to install, you can use the "DWG to PDF.pc3" to use the plot command for creating PDF-files.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Just create a PDF file that is the proper size. You can then send these files out for printing.
