Alfred.NESWADBA
en respuesta a: Anonymous
>> qselect tells me that there are 11 items on that layer
Then select these objects, run command _COPYBASE (using point 0,0,0), then create a new dwg-file and use command _PASTELCLIP to paste the geometry ... do you see that now?
Which type of geometry is it? If these objects are block-insertions then you might have thawed the block insertion layer, but if the block has all it's geometry on frozen layers you won't see this.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
