- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi guys, I'm new to the forums and this would be my first time posting here. I'm new to autocad and I was looking for an way to move my sketch into the front plane because by mistake instead of sketching it on the front plane I sketched on the top plane. Is there any way if i can transfer this drawing from the top plane to the front plane? I'm using Autocad 2018 Student Edition.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
commands _3DROTATE and _ROTATE3D, both can do that.
Also if you first set your UCS to right or left you can use command _ROTATE).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thank you Alfred, it seems to work but I need to 3drotate to the Y-AXIS. Is there anyway I can go to the Y-AXIS Because When I rotate it I'm on the X-AXIS.
Update: I got it to work I used the Gimizos In 3D Tools.
Thank you Alfred, It works great!
