- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Doesn't read measurments I type
I intalled AutoCad but I immediately realized it doesn't read the measurments I give it, so my lines, for example don't extend to measure what i type in
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
<<<<<I intalled AutoCad but I immediately realized it doesn't read the measurements I give it, so my lines, for example don't extend to measure what i type in >>>>
do you mean fix Rotated dimension with line, to be change ???
if Rotated dimension is DIMDISASSOCIATE when line change dimension never change
About Associative Dimensions
Click here
Jayhar.M.J
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Some questions:
- Did you try this in a new drawing without any other geometry?
- When you enter the distance, what exactly did you type in?
- While you are entering the distance, where is your cursor positioned?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
What i mean is that when I have to place a straight line for a perimeter,
for example, and click in one point, give the line a direction and try to
type in the length I want it to be, at that point it doesn't take the
command I gave it.
I hope it's a little more clear
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
please check Keyboard Num lock is On
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Can you do a >>Screencast << of the steps you are taking?
Do you have dynamic input on or off? If you have it on it expects distance [tab] angle.
If you are using the command line it is <angle[enter]distance[enter] .
Nancy
@Anonymous wrote:
I'm sorry i'm not english and can't express myself correctly.
command I gave it.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
If you are trying to enter a length with feet and inches you need to change the length type with the UNITS command. A dialog box will display, in the upper left you,I assume, will want to pick Architectural. Now go back and try again.
After you enter the first line length, exit the line command. Now Zoom Extents. Do you see it now?
GrantsPirate
Piping and Mech. Designer![]()
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
The "INSUNITS" command is a thought. I'm a command based user, so I can't point you into the ribbon based junction. Hopefully this helps!
-Mike
