- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Classic Layer Properties Manager, slow with multiple refreshes. ACAD 2017
AutoCAD 2021
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
>> Classic Layer Properties Manager recently in AutoCAD 2017. It
>> frequently becomes very slow by refreshing the layers multiple
>> times when a selection is made
May I ask what you mean by "classic layer properties manager"?
Because while this dialog (the classic layer manager) is open you can't select objects in the drawing.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I'm not making selection within the drawing, I'm making selections, changing properties in the Layer manager (ie colour, status, linetype, etc). Below is a screenshot of the Classic Layer Manager
AutoCAD 2021
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
which reason do you have to use the old layer manager?
What you can try is to disable system variable SHOWLAYERUSAGE (>>>details<<<) as well as LAYEREVAL (>>>details<<<).
Also please let us know if that happens with a new drawing, based on an original AutoCAD template too.
- alfred -
Alfred NESWADBA
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
well, I use it because it is way faster than the new one.
I just installed an quite fast new desktop. i9, 64GB momory, fast flash drive, the layermanager is slower than ever before. I can actually COUNT the selected layers while selecting. I am also 100% sure that back in the days with autocad 2004, it was pretty fast. I am very afraid of what is comming next with each update...
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
>>>...I mainly seems to happen with drawings that have had pointclouds inserted into them, via cloudWorx...<<<
That's just the nature of working with pointclouds: there is not a PC fast enough on the planet to help.
BUT... you are using a 4-year old version of AutoCAD too, at this point you probably should be using AutoCAD2020 (works a bit faster with pointclouds) if you want help from Autodesk and most end users around these forums.
HTH
