01-11-2019
06:37 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-11-2019
06:37 AM
Noticing that you made a good effort to create all of the linework that would represent the edges of your 3D objects. A reasonable thought certainly in "how can I make this a solid model".
It appears that you only have flat faces for this model so I can suggest that you create surfaces (faces) for each of the boundary areas. Then you can use SURFSCULPT to generate the solid as long as you have all faces pre4sent and the surfaces form a closed model.
BTW... A more complex model would surely require better technique, as recommended by others.
Best,
Blaine
