m_angel_lopez94
en respuesta a: Anonymous
Your best bet and easiest way to make the object into a 3D solid at this point is to:
1) Use the "Join" command to join sections of lines together into closed polylines,
2) Use the"Extrude" command on all closed polylines, extruding them further than the extents of the shape you want
3) Use a combination of "Intersect" and "Subtract" commands to chisel out the shape you want.
In the future I'd suggest using commands more aptly suited for 3D Modeling such as Box and Wedge.
Hope this helps!
