Pantaleon02
543 Vistas, 3 Respuestas
File from Autocad 2018 now in Autocad 2019 has text/font problems.
I was working a file in autocad 2018, and tried to continue it in another pc with autocad 2019.
And now the text has problems.  Part of the text disappeared.
I tried with the command  AUDIT,   PURGE, OVERKILL, and it's still the same.2018 version2018 version
2019 version2019 version
How can I fix this problem?
ennujozlagam
en respuesta a: Pantaleon02
hello, have you try to install latest updates from autodesk and see if helps. thanks
Alfred.NESWADBA
Does the other PC have the same fonts installed? Maybe the text behind "(V2)" is created with a different font?
Also please try to turn off hardware acceleration (command _GRAPHICSCONFIG).
When you select the text "(V2)" on your screen, what text does the property window show?
If you can upload the dwg-file, it would be great.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
pendean
fonts are not stored in the DWG files: you need to go grab your needed fonts from the other PC and install them on this PC with the font issues.
