mdhutchinson
en respuesta a: john.vellek
Thanks for taking a look John!
This is an issue the receiver of our drawing file encountered. I was trying to replicate it on our end.
The only way I found to do this was to:
  1. Select the PaperSpace dimensions.
  2. In Properties Palette under Misc, click on the small control to the right of the Annotation Scale entry to bring up the Object Scale List dialog.
  3. Click the Add button and select 3/8"=1'-0" for instance.
  4. Then before clicking the OK button, select the 1'-0"=1'-0" and click the Delete button.
  5. Click the OK button to dismiss the dialog box.
  6. The 3/8"=1'-0" Annotation Scale Rep now controls the size of the Dimension Features.
This is the only way I found to duplicate what the user was seeing.
The reverse of this procedure is what I am thinking will fix their issue with our drawing file.
Just how this happened I have not been able to tell, except to do the above procedure.
