mdhutchinson
en respuesta a: pendean
Here is a copy of the drawing file that we sent... of course without border and xrefs... the layout tab has the dimensions in question.
Your take will be much appreciated.
You may find proxy objects in the drawing's database, but that should not trouble your investigation.
Also, there was a Dimstyle override on DIMLFAC... when the dimensions were done initially.
Side Note: I disagree with doing overrides, but that is how a third party software we use deals with dimensions in paperspace... the software allows you to use virtually any arbitrary scale on the viewport. The factor is pretty close to 3/16"=1'-0" but not quite.
