Alfred.NESWADBA
en respuesta a: Anonymous
>> By the way,  why drawing views can't be copied or
>> exploded in AutoCAD 2018?
Drawing views are objects introduced much later than AutoCAD 2004 was released. And so these objects are one of those that were not able to be saved back to older releases.
The chance you have is to use _EXPORTLAYOUT to get them saved as plain lines and arcs, theses type of objects can then be save back to older versions of dwg-format.
>> But you know,not everyone have new version of CAD
If you need to exchange data from your quite current AutoCAD 2018 with software that is more than 10 years old then you should only use objects and object-properties that were available in that old releases too.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
