- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Tool Bar visibility
Does anyone find the visibility of tool bars ridiculous? Blobs of baby blue and orange? Really? How about black and white line work graphic you can actually see?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Turn off GRAPHICSCONFIG
or
CUIx reset to its original state Click here
Jayhar.M.J
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
That is one of those questions: if you ask 10 people you'll get 11 opinions.
It is close to impossible to create icons in a way everyone would be happy.
The chance you have is to modify the color scheme ==> command _OPTIONS ==> tab Display and switch between "Dark" and "Light", chose the one you like more.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Have you considered not using AutoCAD? That maybe would help solve your issue.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
There is no solution and Autodesk is just keeping up with marketing; basic icons is the new thing. Since they can't get simpler they should have more detail next time they update the icons.
Possible solutions: Increase screen resolution. Use the Ribbon since the icons are larger. Create custom Ribbon panels with the commands you use most often. Add the commands you use to Tool Palettes since they allow you to control the size of the icon. You can create custom icons and create your own toolbars. Ask on the Customization forum since someone may have already done this and could share theirs with you.
It sounds like you may just want to vent, but there are solutions that may make it a little easier.
Nancy
@Anonymous wrote:
Colorful blobs on a light or dark background isn't really a solution.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Toolbars are old school. There is going to be a day when Autodesk won't be able to support them anymore. Embrace the ribbon in all its glory.
Rob
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
The ribbon is current, buddy.
The command line is also going away.
Rob
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Doubtful. AutoCAD is too entrenched in production around the world.
But I guess if they do yank the command line, maybe that will be the straw that moves us to BRICS. Autodesk has added very little truly useful functionality in 20 years and certainly not enough to justify their horrendous pricing model.
But I digress. Maybe you're right, but watching my users peck through the ribbon is just excruciating.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Oh, you're one of those. Please disregard.
Rob
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
lol - not only am I one of *those* (#CLEANSCREEN baby!) but I learned in an office where they had mapped all the predominant commands to keys that sit under your left hand so you didn't even have to lift your wrist up to key something silly like L for line - G was LINE! It was def insane and something I've moved away from, but good god could you draft like a demon (provided you understood what it was that you were drafting).
So yeah, seeing "the kids" coming in today asking, "You guys don't use Rhino here? Why do you use AutoCAD?" and then watching them move their cursor over to the "line" button *click* then back to the canvas and clicking the start of their line while running the perpendicular OSNAP is just.... ew.
Anyway, I'm moving out of drafting the older I get so all I have are these forums and clouds to shake my fist at!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Then place in a single folder, path into 2019, start CUI command, select each and ever command in the CommandList that you like to use and make the substitution in that command's Properties section (at the bottom).
Which older version did you migrate from?
