01-04-2019
12:29 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-04-2019
12:29 PM
object snap or 3D-object snap should not influence the result ... except you have set this option to not default:
Start command _OPTIONS, tab "User Preferences" and make sure the marked settings is the same as in the screenshot:
You can look to my video here, it shows that using your 3 points with your drawing works well.
I don't know why you think that a point - when you entered the coordinate - is not used by AutoCAD.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
