12-26-2018
12:07 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
12-26-2018
12:07 PM
Are any objects with 'dull colors' on a layer with transparency greater than 0? To determine if any layers have a transparency value, check the transparency column in the Layers Prop Mgr. If you don't want the objects to plot transparent, change the value to 0 so they'll appear solid and plot solid too. If you want the object to appear normal in modelspace but still plot transparent when you print, then you can turn off the transparency while in modelspace and simultaneously maintain the transparency during the plot.
1-Transparency column in Layer Prop Mgr.
2-Variable is transparencydisplay (description shown above).
Chicagolooper
