548 Vistas, 1 Respuesta
Publish VS. Print to PDF
Hi - I am getting different outcomes when I Publish PDFs vs when I Print to PDF. The drawing/lines and text come in much lighter when Published. I would like them to be dark like the Printed to PDF document. Please see attached. Does anyone know how to fix this issue?
Alfred.NESWADBA
en respuesta a: Anonymous
you used different printers, the PLOT was done to Adobe Printer (Acrobat Distiller 15.0) whereas the PUBLISH was done using the AutoCAD internal driver (pdfplot13.hdi).
You should make sure to use the same device for _PLOT and _PUBLISH.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
