221 Vistas, 1 Respuesta
Sectionplane Error
While creating 2section plane placed in this dwgsection plane placed in this dwgThis is the dwg export as 3D object from that section planeThis is the dwg export as 3D object from that section planeD/3D block from section plane i got this issue. The 3D solid was not coming in proper solid object.
Etiquetas (1)
john.vellek
en respuesta a: Anonymous
Hi @Anonymous,
Which version of AutoCAD are you using? Can you share this file so I can take a closer look?
John Vellek
