- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I agree @pendean, it would be good to find out if the functionality works at all and the problem lies with a messed up command sequence in the ribbon command links.
Another quick check on functionality would be for the OP to simply CTRL+C a JPEG file (or other image file) from a windows folder and CTRL+V into an ACAD drawing. This should step through the traditional process of placing, scaling, and rotating the image. He would end up with this on the XREF list if all goes well.
Also, for an OLE insert check...
Open an image in MSPaint, select all or part of the image, CTRL+C, go to ACAD and CTRL+V. The selection should drop into ACAD as an OLE with no issues.
If any problems happen with those processes then surely he has problems functionally and not just with the command link sequence.
Blaine
