- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
John, as I said in the original post, we are using Autocad 2018 and we are using the Import command as you suggested. But, there seems to be a bug that causes the Open File dialogue to filter out all files except point cloud project (RCP) files. In my original post I included a screenshot showing the dialogue box that opens when I use the import command. This is not a problem with not knowing how to import or attach images, I've been using Autocad since 1989 by the way. This is a bug and I am trying to let someone at Autocad know, and maybe see if there's a fix for it on the way.
Thanks.
Darin
@john.vellek wrote:
Hi @Anonymous,
What version of AutoCAD are each of you using?
In 2017 or newer, you can use the PDFImport command to insert a vector-based PDF as vector geometry.
IMAGEATTACH should allow you to attach other image files.
In addition, through the External Reference Manger, you can also attach files.
If these aren't working for you can you walk me through your exact steps (along with some screen captures)?
