john.vellek
en respuesta a: Anonymous
Hi @Anonymous,
What version of AutoCAD are each of you using?
In 2017 or newer, you can use the PDFImport command to insert a vector-based PDF as vector geometry.
IMAGEATTACH should allow you to attach other image files.
In addition, through the External Reference Manger, you can also attach files.
If these aren't working for you can you walk me through your exact steps (along with some screen captures)?
John Vellek
