- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Windows 7/10 OS denotes every folder on the system as Read Only. What this does for AutoCAD is create an error that indicates can't autosave to a read only folder. After hitting ok, I noticed the files were still saving. I had (3) MS techs go thru the system by VPN, tried to fix it, reloaded Win OS twice and they finally said, this is the way MS is, the vendors will need to fix their software. MS indicates even though the folder itself has a read only attribute, the files themselves do not and Windows Explorer allows the files to be read-write. This is not limited to AutoCAD, my third party plug-in software, SprinkCAD, is having a worse problem. That program won't read-write a specific file, deletes the file, making the software unusable.
¡Resuelto! Ir a solución.
