459 Vistas, 3 Respuestas
convtosurface command is not working
I want to convert this mesh into surface.
I tried the command, convtosurface, but this command ends with error.
I want to know the reason of this problem.
If it is the problem of my PC, please let me know the required features of CPU or RAM.
jayhar
en respuesta a: Anonymous
Please upload AutoCAD 2013 format & Visit here https://forums.autodesk.com/t5/autocad-forum/planesurf-and-convtosurface-command-not-working/m-p/721...
Jayhar.M.J
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Alfred.NESWADBA
What was the error? Which message did you get?
Also which version of software did you use (please show us a screenshot from command _ABOUT)
Hard to know without know your error ... :cara_guiñando_un_ojo:
From what I tried I could guess that it's a question of memory amount, my 32GB were not enough to convert your 300.000 vertex mesh.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
My computer was really struggling with this large mesh as well. I don't know if this is a viable method for you but if I explode the mesh I end up with faces which convert to surfaces quite easily.
This obviously will yield many surfaces instead of a single one.
John Vellek
