- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Exporting Palettes and Palette Groups
I need to export a set of palettes and I don't know what the most effective manner is to do so. I have nested groups 3 levels deep and a TON of palettes (70 or so). All palettes are stored at the bottom level; first two levels are really just for organization. I can export the groups (.xpg) but it really only exports the folder structure. Am I to understand that to recreate this palette group on another machine, I would have to export all the individual palettes and then place them in their corresponding groups through the customize menu?
This is an enterprise level effort. I need a way to recreate this palette on a couple hundred computers.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Where did you get stuck? Testing on one PC before you go to 200 PCs is the way to start.
TPs are just pointers, they tell each AutoCAD seat to "look here for this item" and nothing more. Those items need to reside in a central loction pathed to each PC in AutoCAD. Is that already in place in each of your 200-seats of AutoCAD?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Yes, I have already searched through the Autodesk documentation. The methods you linked work, but are unfeasible considering I have over 70 individual palettes that need to be exported and then manually imported on each client machine.
Nonetheless, the solution I've found is to just copy the entirety of the Support\ToolPalette folder onto the client machine.
